CRF250L Big Bore Kit work on a 2017 model
I know the throttle body is 38mm (2mm up from 2016) also a revised air-box, reshaped air boot, new muffler design and a larger-diameter exhaust head pipe. my question is can you install a big bore kit on this? i haven't seen anything stating that it will work for the 2017 model (my guess is it will but i'm not an engineer).
Thanks for the help.
I too am not an engineer. but AFAIK they didn't change anything about the cylinder from 16 to 17. since the BB kits only change the cylinder bore/piston size/etc... I'd think they would still fit. any subsequent fuel mapping, ecu programming, etc... would be different one would assume
