take a look at my cylinder
anyone know what this could be? not very deep, will catch a fingernail, haven't honed it yet, should I be alarmed; or should I hone it and worry later? bike ran good, piston looks good, rings right at service limit. appears as if this bike sat a while with a bit of moisture in cylinder....
Do you really want a bike that uses oil?  Also, what bike is it?
Was it running a K&N air filter?
Edited by Baja Rambler
If I needed to race a harescramble this weekend I would hone it and run it. If I was planning to run Dakar with it I would replace it or bore it.
But I might change my mind after honing. Hone it and post another pic.
Edited by Firestone
It looks like the bike sat for a while with moisture in the cylinder and the oil control ring rusted to the cylinder wall.
It is generally not recommended to us a K&N air filter if you ride off-road at all. They don't filter as well as foam or paper filters.
You should be able to have the cylinder bored; this does not require a new sleeve. You will need to take the cylinder and a new piston to a shop that has the appropriate machine to bore the cylinder.
Many owners would take this opportunity to go with a big bore kit. This will bump displacement to around 280cc.
and what exactly do you think k&n filters are made out if not foam or paper.
They use gauze (cotton fabric).
If I have one torn that far down I think I would bore it too.
