I lost one of my nuts
Guy i lost the nut for the mid valve on my kyb 46u forks from a wr250f. Anyone knows what the specs are on that nut?
8x1mm thread, just measure your post will tell you exactly what size
It's a 12 nut so maybe 10x1
If it was a 10mm post, then what size shim Inside diameter would u think they would use on rebound piston???? The clamp was oftern 11mm shims on the rebound on the 46mm kyb, let me know if it's not a 8mm
I'll measure it later and let you know.
why not look on a parts fiche. if you don't want to buy an oem nut theres a good chance it will tell you the size.
