How worried should I be about this?
Getting ready to replace some bottom end bearings and found this...20170607_195643.jpg
The part of the case that will meet the outer racing of the bearing has a bit of a gouge in it. What should I do? Sand paper or am I boned?
LIGHTLY sand any raised areas then clean and install as normal.  You're only screwed if the bearing ISN'T a press fit...
