Power valve cover
Just snapped a bolt on my powervalve cover and it's stuck inside the case. Is it ok to run without this one bolt and how do I get the bolt out? Image1496882476.672413.jpg
should be ok - maybe remove the cover and put some gasket goo on there. you could also attach a strong spring on the cover hole then attach the other end of the spring to the frame or somewhere on the engine
3 hours ago, mritch8 said:
Will it be ok to run without that bolt for the weekend?
You are fine to run for the weekend. Sears Craftsman makes a pretty good extractor set that pulls bolts out with ease.
