Xr200r/xr250r aftermarket hubs?
Does anyone make aftermarket front/ rear hubs for the xr200r or xr250r?
Sometime in the future I plan on prettying up my xr200r. Yes it's a 27 year old bike, and I'm not making a show bike, but I try taking pride in my toys, and want to make it looking good enough to have people say "damn, that's a nice bike".
Changing the color of my hubs is one thing I wanna do. Either powder coat or anodize the ones I have, or find aftermarket anodized.
I'll have the '84 xr250r forks with disk brake, and eventually probably do xr250r aluminum swing arm with disk brake. Would that help in finding hubs?
Also, should I get my wheels powder coated, or go with aftermarket? Will any brand work? Any info always helps, thanks.
Daniel
The 17mm axle limits you a little. As far as drum brake hubs go I have never seen anything besides stock. If you disk you can use the xr400 hub or the late model xr250r hub, I think they are the same. I do think that the cr 125/250 hubs could work spacing wise, but you would need to figure out an axle conversion.
Sometimes a bearing exchange will adapt a wheel to a different size axle, I have a RM rear wheel on my XR218.
Look up the wheel bearings on the Honda part fiche, they have the Metric standard part number in the description. Some wheel bearings, and sizes,  from my notes:
Brg #....... ID........ OD....... TH........
6001........ 12........ 28.......... 8........
6201........ 12........ 32........ 10........ CR80/85 f
16101...... 12........ 32.......... 8........
6301........ 12........ 37........ 12........
16002...... 15........ 32.......... 8........
6002........ 15........ 32.......... 9........ CRF150R/RB f
6202........ 15........ 35........ 11........ CRF150/230 XR250 f
6302........ 15........ 42........ 13........ XL185S r
6003........ 17........ 35........ 10........ 89-91 RM125 f, 86 89 CR1251
6003........ 17........ 35.......... 8........
6203........ 17........ 40........ 12........ XR200R & 84-89 XR250R r drum side, 90-03 XR250 r disc side
6303........ 17........ 47........ 14........ XR200R, 84-89 XR250R, 96-03 XR250 r sprkt side, CRF230F r
6204........ 20........ 47........ 14........ 89-91 RM125 r, 90-95 XR250 r sprkt side
6004........ 20........ 42........ 12........ 315R Front
6904........ 20........ 37.......... 9........ CRF250 f
6304........ 20........ 52........ 15........6006........ 30........ 55........ 13........
