Line routing for Keihin PD
Well, I made the mistake of not taking notes when I pulled all the lines off the Keihin PD carb on my 1980 XR200, and now I don't remember exactly, plus manuals are a little vague, and that doesn't mean stock was the best arrangement, some of you may have a better recommendation.
I assume there was a drain line permanently attached, and it was normally pointed up under the seat and fixed in that position when not being actually used to drain the bowl?
Was there a vent line permanently attached, even though the vent port doesn't have a barb or ridge to hold it? Was this also pointed up under the seat and fixed in that position?
Any help appreciated.
Thanks. I was more worried about how to run and attach them to the frame, but it is good to know for sure that the vent port definitely needs a line.
