Oil Cooler
Any good newer write ups on installing a xr250R or XR400 oil cooler on a 06 XR650L
They don't provide nearly the cooling of a tube and fin or tube and plate cooler.
I thought the xr400r cooler was a fin & tube? (flat tubes)
can`t imagine that cooler doing much good shoved in behind the headlight,,,the old 400 and 600 had better venting through that area too...all that work,weldding lugs to mount..never saw that cooler being a bonus..
B
Just relocate horn and cut the plastic out, welding nuts can be a hold up unless you have a welder :D  Also weld a tab on the stem to support the bottom of the cooler after you stick something rubber over the stem obviously.
I think the radiators mounted to the side of the engine case are just asking to be squished against a rock on a get off and dump all the slippery stuff in the dirt.  The xr400 cooler may not have the capacity or cooling capabilities but good luck destroying it and being able to walk away afterwards.
the XR400 cooler is not indestructible either,,seen 2 that the cljutch cable ate through from rubbing it on while riding and turning,,the cables make a nice saw when the rubber wears through..🤣
haven`t seen the side cooler take a beating yet,,maybe someday,,but you might be waiting awhile...
B
  • Like 2
That could happen, but mine isn't cutting into the cooler...  (though I'll sand some corners off by the looks of it, it's been on for the past 7,000 miles like that with a 3" bar riser to boot!!)    I'd have crushed a side cooler a few times by now but if you keep to the pavement I'm sure you'll never have a problem 🙂
The throttle cables are the two zip tied together on the far right in the picture, past the grease zerk 🙂
Edited by Notabiker
forgot shit
A lot of my cables had to get rerouted when I did the 3" powermadd riser block but everything is still original, and if you're going to do a riser then do a powermadd as it's probably the strongest one out there.
