250 xcf not starting
I have a 2012 KTM 250 xcf that wont start. It will back fire about every 5 kicks. I have cleaned out the injector, checked the timing, made sure it was getting spark. I don't know what else to look for could really use some help. thanks
You have to tap into the system with a pressure gauge, most dealers have the setup
Have you checked the fuel filter in the tank and the inline one ?
Even sometimes the snap connector in the fuel line isn't fully together
I haven't yet cause when I would be trying to start it, I would pull out the spark plug and it would have obvious fuel on it. but I guess it could not be getting enough I will check the filters and connection. thanks for the help.
