RM250 TOUGH CLUTCH
I just recently got a 2001 RM250, and am having problems with the clutch pulling out, either I so not give it enough throttle and it bogs down and stalls or I give it too much and it wheelies. Is there anything I could change to fix it? Or any tips you guys could give me on pulling out with a racing clutch? - Shaun
12oz flywheel weight. And Hinson pro clutch kit. And up the rear sprocket a tooth or two.
thank you!
Do you notice any difference in clutch action between hot or cold engine? Sometimes the first release on a cold bike is not very predictable...
No it's kind of wierd it is better cold than warm
That's one thing with the RM, the clutch engagement is somewhat comparable to a on off switch. If you say it's not worse when cold, maybe try a heavier oil. I like 15w40 in the clutch and transmission in part for a smoother engagement when the bike is hot, but you will notice it gets worse when cold.
yeah RMs are wierd
