Tires Tires TIRES
Anyone that may have some input on this, please respond.        I have a 2013 CRF450R.    The recommended tires are 100/80-21 and 120/80-19.     What if I switched to 100/90-21 and 120/90-19?  I LOVE the look of big chunky tires and have settled on the Maxxcross Desert IT's for my next set.     If I went to the bigger sizes for both front and rear would it cause any problems ?
The "look" of a tire is entirely irrelevant.  Does the tire work for your given riding style and terrain?  That is the only important question.
  • Like 6
Why dont you get an 18" rear wheel. And run a woods tire. It will have a nicer ride and be more forgiving almost everywhere. And tire choice increases
Firstly the only difference in those tires are the height and not the width
100 or 120 is width
80 or 90 is height
Personally the Desert IT's front/back are one of my go to tires mostly cus they are really durable and I can run the back as low as 2 PSI with a UHD tube BUT IMO no one is going to be able to tell you how a tire will work for you so just have to buy them and try them.
Another one buying into the Maxxis hype. :smirk:
Lol.
Im not big on the maxxis stuff. I run a bridgstone m102 rear. But i ride in sandy sort stuff mostly. Or clay dirt.
100 or 120 is width
80 or 90 is height
No   I'm with you.  No one can tell how a tire will work for me. You are right.        I guess I was just trying to find out if there is any reason why I shouldn't go to the bigger tires.
Yes I have personally not tried Kendas BUT I'm fully aware they can be durable and less expensive than Maxxis but as I said you really need to buy tires and try them out.
Currently I'm trying a Shinko 505 rear and 546 front which are NOT anything like the Desert IT or say a Trackmaster II and I'm liking the rear for the current conditions BUT I know its going to wear fast once I start riding hard/dry/rocky stuff in the next few weeks. Then I hated the front until I dropped the PSI to about 8 PSI but its more durable than the rear.
I've considered it.
I've considered it.
I use an 18 all the time. And have a 19 i keep just with a paddle. But ive never ised it. I am definitely not the tire expert here. The only tires i habe ran are irc m5b, bridgstone m102, dunlop mx52, and i had a kenda a long time ago. Bit all of this is kinda irrelevant to your question originally. Short answer is. If it fits it fits lol. But i agree. Mire tire less rim looks good imo also.20170319_211501.jpg
Niiiice!
Lol, we've been down this same road a hundred times, I couldn't resist.
Anyway, I think the OP is FL anyway, neither the Maxxis or Kenda desert tires is probably a good choice.
Edited by cjjeepercreeper
36 minutes ago, Btheseven said:
Why don't you like Maxxis?
See the above reply to filterx, this is a long standing ribbing about the Maxxis vs the Kenda desert tires. If you really wanted to you could probably find a couple dozen back and forth posts on this subject, lol.
  • Like 2
I wouldn't have used the word "entirely"     A tire that looks chunky  is "chunky"   It has more rubber sticking out of it to grab things.  Like substrate lol     I do understand what you meant though. Thanks for the input.
So I live in BC Canada and my local trails are the PNW and then I can go other places and ride a HUGE variety of terrain and conditions.
Fast/flowy/slow/technical then wet/snotty/slippery/rooty then dry/hard/rocky.
I am by no means an expert on tires and since I've gotten my 250R in 2010 have really only tried a few makes/models of tires and when it comes down to it there are about 1000 different tires options and not enough $$$ or time to try them all.
For example this is a 19" Maxxis Desert IT vs a Michelin HARD rear that I tried last summer.
Then I just put a 18" rim on and heres some pics I took today of the Shinko 90/100/21 front and 110/100/18 rear.
20170610_115904.thumb.jpg.d8cd3c2ab562fe78733a5dc4c8e9bcdd.jpg20170610_115834.thumb.jpg.bd511ab1bb0a31860077a3fbd52d4083.jpg20170610_115851.thumb.jpg.b9616d3c0eba53dc6f29810412176b67.jpg
Anyway, I think the OP is FL anyway, neither the Maxxis or Kenda desert tires us probably a good choice.
Has there been a lot discussed here regarding tire dimensions?  That was really my main focus.  I threw the Desert IT's in there as a sideline interest.  I realize this entire post could get led into the tire brand thing though.   If it does it was not my fault.
Sorry I meant to post this which gives you a good idea
https://www.denniskirk.com/learn/tire-sizes-explained
