2011 ktm 350sxf bogging on the bottom/under load
so my brothers 350 is bogging off the bottom and i have no clue what it is i checked inline fuel filter and cleaned injector so i have elimanated that. my local ktm dealer thinks the crank could possibly be tightening up causing the bog. i hope its not the crank but could this be anything else? i dont think it is an electrical issue but i have never checked the valves on it and it has an unkown amount of hours so i should check them but besides that could the valves have anything to do with this? the stator is reading on the low side from what they told me when it was in the shop but they said i shouldnt have any issues with it. im out of ideas here im new to these high tech thumpers. thanks for any imput
If the crank was going it would not run for long , fuel pump is possible, fuel filter in tank
i pulled the filter and it was black so i hope this fixes it
replaced filter same thing if not worse its almost like its getting worse the more i run the bike now it nearly flames out if you give it any kind of throttle at all.
I woukd check the fuel pump pressure
