clutch side casing removal
hi, been rebuilding a dr600 but after finally getting the full power fuelling right, the clutch wont stand it,
so new plates and springs arrive and i go out to strip it, but whatever i do i cant shift the casing
the front does move slightly with a good clout from a rubber mallet on the side,
but you cant do that at the rear where the locator peg is,
theres no "Knocking tabs" either which doesnt help
after the rubber mallet i got a hardwood dowel in where i could using it as a drift , with no joy at all
even tried a phosphor bronze drift gently against the casing where it protrudes slightly
just cant shift it at all
short of taking the engine out and soaking it in paraffin im at a bit of a loss
all ideas greatfully recieved :-)
Your gasket is stuffed anyway - just use a thin blade - like a scalpel blade along the gasket line to break the seal
its probably that rear locator peg thats holding it or you missed a bolt
no way mate, any steel blade is harder than ally, i was always told never to force anything into the edges because of damaging the faces of the casing,
and learnt the hard way with an old A7
but, its done :-)
tapped 4 of the bolt holes in the casing itself, and then gradually wound in 4 bolts, as the bolts reach the narrower hole in the crankcase it forced the casing off
happy days :-)
where theres a will theres a way :-)
