Leaking rear master cylinder
Since I won't be riding for a while I'm trying to get some things figured out with my Drz. When I bought it the rear brake reservoir was bone dry. I filled it up and now a couple months later it's pretty low again and I noticed after it had sat unused in the garage for 2 months because of my accident there was some brake fluid on the outside. Is there any common spot that leaks? I have no clue where it's leaking from.
i'd say the lid is the most common spot .. the plastic reservoir can get distorted, just get into it, straighten out the accordion gasket, fill it and bled some fluid through it .. if its leaking anywhere else it will likely be obvious ..
