01 Honda cr250r build
As the title says, I'm gonna be rebuilding my 01 cr250r after I drowned it in a creek. Right now, the bike is all apart and I'm waiting for my parts to arrive. BTW that's a pretty worn out bike so it will just add more fun during the rebuild process. Here's a parts list of what I'll be installing on it :
-OEM internals ( already ordered and waiting for them) that includes all the bearings/ seals, the crankshaft and the piston plus some bushings and the gaskets
- Cylinder re-coating
-Boyesen Rad valve
-Boyesen clutch cover and ingnition cover
-Hinson clutch
-Pivot Works bearings for the wheels, steering stem, linkage and swingarm
-PC works pipe and 204 silencer
-Acerbis replica plastic kit
-Decal MX custom graphic kit
-DID x-ring chain
-Renthal sprockets
-UNI air filter
-Pro taper 1 1/8 handlebar metal mulisha edition
-ASV clutch perch/lever  and brake lever
-Footpegs (still have to decide which one I want)
I'm also polishing the frame swingarm and subframe , giving back the engine it's factory look and I already have a keihin pwk A/S for it. I still want to buy excel a60 rims but that'll be in the future with new tires. While I'm waiting for my parts, I started to clean/polish the frame and the other parts that needs to be cleaned here's a quick look at the frame before and after clean up. BTW that's just using regular dish soap some scotch-brite and aluminum wheels cleaner
  • Like 2
1 hour ago, CRJohnny said:
If you want a mirror finish get a drill and some polishing wheels .
That's already done.
-Boyesen Rad valve
-Hinson clutch
-DID x-ring chain
-Renthal sprockets
-UNI air filter
19145891_745148575658230_647318239431903001_n.thumb.jpg.53705a0feb3f3a1b0df0dada1c56f728.jpg
19105571_745148468991574_4215445743793913663_n.jpg.75a769932cf597a0c7f99f4dcc2aa800.jpg
Here's my 01 CR250r I just finished rebuilding & big time modifying about a month ago. Did a big bore & much, much more. ..FB_IMG_1496015125686.jpgFB_IMG_1496015485835.jpg1496340722854.jpg20170514_015734.jpgFB_IMG_1496015547985.jpg20170325_101923.jpg20170407_213007.jpgtmpPhoto.jpg20170312_121711.jpg20170312_121618.jpg
Here's my 01 CR250r I just finished rebuilding & big time modifying about a month ago. Did a big bore & much, much more. ..FB_IMG_1496015125686.jpg.2fb7972dbaeebab40574d9401db72ceb.jpgFB_IMG_1496015485835.jpg.519ca9831710331449fab9ef390d18ab.jpg1496340722854.jpg.0e67c2e4339966459b06926b6a1c94a6.jpg20170514_015734.jpg.3a22d71f736dddc48361d90fd2ca6a58.jpgFB_IMG_1496015547985.jpg.8e1bda082610dfa1280ef84ad177ccc7.jpg20170325_101923.jpg.03db41794cc7aae21507f216b9a77189.jpg20170407_213007.jpg.4492b3aa81f857ac7211bbbf68156e52.jpgtmpPhoto.jpg.5fd0fd1339b86dc00deff4474e6a00e6.jpg20170312_121711.jpg.3f798ab17f6b933a9fda8313a3c5f15f.jpg20170312_121618.jpg.d1875b95558182785fd0789752bdc0fe.jpg
That's a really nice looking bike that you have there! I'm also looking for powdercoat on some of my parts
That's a nice bike man good work I am in the process of rebuilding my 01 cr250 aswell going all oem internalls and going for a new modern Honda look
Alright so little update guys I received most of my parts to rebuild the engine I still have to get the piston but my local Honda dealer cannot have it until the end of june also I'm gonna go get some muriatic acid to clean the base and make it look like new.20170616_162229.jpg
Edited by jackstrap
It's been a long time since the last update and I got a LOT done to the bike.  Most of it was cleaning and getting everything  ready for the new parts. From the pictures you can tell that this bike was totally worn out. I was afraid at the beginning of the linkage disassembly that I would have to find new linkages but I've been able to remove the old rusty bearings with a press but the sound it was making was driving me crazy! I also got the cylinder replated and now the bottom end is almost rebuilt I still have to center the crank and get my new clutch installed but that'll be in the next few days. All the parts have been soda blasted so they look like new but for the crankcase I also used miuratic acid to remove the stains in the aluminum. Also I got the crankcase repaired by a machinest as it was cracked on the bottom. The rear caliper images will tell you what soda blasting can do that's a before/after comparison
Edited by jackstrap
This is my 01 cr250 r I finished about 3 months ago. Good luck with yours. I'm glad to see another one getting rebuilt....
FB_IMG_1496015125686.jpg.2fb0266900e837a3dfcd323c200d8635.jpgFB_IMG_1496015485835.jpg.5c98f4fb89ade9deb4c44cd97a1a41d6.jpg1496340722854.jpg.f1a07ff1de67a44f42303c625127aaca.jpg20170514_015734.jpg.d99a3455c43cc347fae023e910055fc5.jpgFB_IMG_1496015547985.jpg.97898795f30a97f02b3de938723e5fec.jpg
Is that the same one you posted before?
It's one that I've posted in the past, yes. I believe it was the last "fresh rebuild" post I did on this site.
Whats your thoughts on it, do you like the way she came out? The finished product?
I really like how it turned out but the only thing I dont like is the black frame IMO you should have let it bare aluminum
I much prefer the oem fuel line. And if you are using ethanol fuels be very sure the in line filter is spec'd for them. If not it WILL become brittle and come apart at the worst possible time.
Well guys I apologize for the delay I've been really busy during the past weeks but I had quite a lot of time to work on the bike. Here's more pics of the project 20170722_162047.jpg20170722_191017.jpgreceived_775361299303624.jpeg20170723_162829.jpg20170728_122148.jpg20170729_145919.jpg
Sent from my SM-G920W8 using ThumperTalk mobile app
Thanks
Sent from my SM-G360P using ThumperTalk mobile app
Thanks
