Wiring SR500
??? It is plug and go. The plugs are not interchangeable to function.
Try here if you get lost. Marcus has a fair bit of troubleshooting and wiring data for the Yamaha 500 series. Note that your ignition parts must match to type. Not all 500's used the same CDI and you can not mix. You don't need the battery/charge and voltage regulator, etc to run the bike if you are racing. You can also try at the SR500forum. There is a good number of Yammie 500 crazies there.
http://www.rexs-speedshop.com/epages/es143131.sf/en_GB/?ObjectPath=/Shops/es143131/Categories/Tech_Support
http://www.sr500forum.com/vbforum/upload/upload/forum.php
