KLX110 Kick Starter Skipping
Hi all.
I have a 2006 klx110 with a 143cc big bore kit and the kick starter is slipping.  I've read the threads that say replace the one way clutch but do you just need to replace the part with the rollers or do you replace the center collar too?
Thanks,
Mike
Not the clutch. There's a one way bearing that you need to replace
Edited by 912
To add pic
It might be the clutch if you still have the stock springs, check that first the one way bearing costs more than an hd clutch pack. I have a 143 kit with the stroker crank and mine slips unless I have all 6 hd springs in. It slipped the same way with the stock crank and I wasted $50 or however much on that bearing before I realized it was the clutch slipping from the compression.
