What's this nipple on my intake?
It's an 03 klx110.
Bike is a little lean. Idle hangs. I found this nipple and it's sucking in air. Is there a line suppose to be ran to it? Or just blocked off? When I plug it with my finger idle drops big time. I'd imagine I would need to mess with the settings.
Thanks
No idea what or where it is supposed to go to but one thing is certain it is not supposed to be open and needs to be either blanked off or the original plumbing refitted.
Thanks. Most all the pics I see it's either blocked off or the intake just doesn't have it.
Hmmm
Thanks for the suggestions. Unblocked it off and bike runs great now.
It's an 03 klx110.
Thanks
What did you end up using to block it off?
Some sort of vacuum port. Just put a rubber plug on it. Vacuum leak should go away and idle should return to normal
Supposed to be a rubber cap on it.  Nothing runs to it, they come brand new with a rubber cap on that nipple.  Something to watch out for, without the cap your are sucking unfiltered air right into the motor.
