07 kx85 runs, no power band
Recently rebuilt an 07 kx 85 with a replated cylinder,pw was completely disassembled and cleaned,vertex piston and rings stock size
Bike fired right up but wont run clean when pw opens, just no hit and bogs. KIPS is properly indexed and actuating when throttle is opened up. Running a br8eg with 32:1  93 octane,h1r oil. Carb is completely clean,filter oiled properly. Reeds seems to be fine, no cracks etc.
Would a bad plug fire right up but not run properly at high revs?
Any insight would be greatly appreciated
Edited by Crustysack
Make sure actuator is connected in power valve
Open carb and make sure main jet and pilot jet are installed, don't take this lightly, just ask turbo dan, I believe had this problem
Make sure no paper towel is in the carb, don't take this lightly, just ask me
No rag in air box
Install new plug, try OEM recommended to see if it makes a difference.
  • Like 2
