Electrical no-start issue
Hey guys got one I need help on. Was replacing the headlight with the led one and got it mounted ok bike started right up and ran good. However when backing bike up to park it the steering locked up early when going one direction. When trying to start it after that no go. It's not battery (fully charged newer battery). When checking up front under headlight cover saw the reason for the steering lock up. That big black connector had slipped down against the stop. It looks ok no broken wires. Here are the other symptoms. With the key on headlight is on but the neutral light will not come on and the turn signal light won't either. Side stand switch is bypassed. All connectors behind headlight are connected. Thanks for any ideas.
Well it looks like there should be a sidestand relay plugged into that 7 conductor plug. Must have fallen off on the way to work. Can't find it anywhere.
