Coolant leaking from side case split line?
Has anyone ever had coolant leak out quite aggressively from the split line on the side case (pretty much right behind the water pump)?
I had a leak from the weep hole so I just took the side case off and inspected the shaft and the water pump seal. The seal looked fine but it was leaking heavily so I replaced the seal slapped everything together, topped up the oil and coolant and fired up the bike to do a leak check. Right away coolant starts leaking (leaking with pressure behind it) out of the split line on the side case. I figured that coolant must have somehow been pumped into the side case cavity so I drain the oil to check and it comes out squeaky clean (no coolant in the oil)? Did I forgot something when I put the side case back on? Maybe a coolant passage on the side case I missed...?
In retrospect when I originally thought coolant was coming out of the weep hole it was likely coming of of the split line and just appeared to be coming from the weep hole.
