Shifter stuck, any tips?
bought a bike and shifter is set low. Trying to remove it so I can replace. I got the bolt off but I cant pull the actual shufter off the pin. It moves freeley and nothing is broken. Bike is a 2012 crf450r. Any ideas how to remove it?
Just tap it from the other side with a drift or punch
Or maybe even this
Corrosion x and if it's a split type just gently tap screwdriver into split to open it a tiny bit then they slide iff. Then take screwdriver out
I use a semi-cheap battery terminal puller for kick start levers that stick after pulling the bolt. You can probably find one at most any auto parts store and you can most likely return it if it does not work (it may be to big to clear the frame)
