Yz60 suddenly lost compression
I got my little 1983 yz60 running. I went to take it for a Ride and realized my clutch cable was way to tightened. So I killed the engine, adjusted the clutch, and now it has no compression!! I just installed new head gasket before it lost compression. When I did I lubricated the cylinder walls with 2T oil. I was told this bike sat for quite some time. So I had it running on 25:1. After it lost compression I removed the spark plug to find a beige colored watery liquid in the engine. I removed the pipe and some more came out. What would have caused this.
New parts:
Carb
Ignition coil
Head gasket
NGK spark plug
Drain the gearbox lube, if the liquid is the same you'll have the answer. (water / moisture in gearbox)
perhaps migrated thru a worn right hand crank seal.
If the gear lube doesn't look watery, then moisture / water just in the crankcase side.
Bike stored outside? (out in the rain, no carb on engine etc.)
Pressure washed forcing water past worn seals / gaskets / intake boot etc.
