Help!!! My KTM 85 sx isnt starting
My 2006 KTM 85 sx isn't starting and believe that the crank is full of fuel or somthing along those lines i have checked for spark and is sparking fine but when i do check the spark plug it is wet after kicking it over a few times!
If you have kicked it to death (maybe you feel like it lol!) then it won't start when the cases are full. Only way to start it is to push it with the choke off and 2nd gear. You'll get loads of smoke which will clear ok. May be you have a carb float issue which is exacerbated if you leave the tap on between races etc. Bob.
