Adjusting air/fuel screw
I just installed JD jet kit and would like to adjust air/fuel screw.  However, I wasn't smart enough to replace stock screw with an aftermarket finger operated screw, while I had the bike apart.  The bike is a 2015 model and the trick about loosening the clamps and rotating the carb won't work and I really don't want to disassemble the bike again just to access the screw.
So, what is the trick to accessing the screww for adjusting or removing?  I thought about cutting the end off a small screwdriver short enough so it would fit.  Ideas?
Edited by doomaflotchy
I have found a couple of special tools.  However, no one knows if it is a slotted fitting or if it requires a "D" bit.  Can't see in there to tell...
