2001 Yz426f cooling mods
I just picked up a 2001 Yz426f. freshly built top end. I'll be doing more trail riding than mx track. what are some good modifications that actually fix the low speed overheating issues?
Coolant catch bottle off a WR
Riding it like it was designed for, on an MX track!
Okay thanks for the feed back fellas. Is evans better than or equal to engine ice? I just put engine ice in it. What about the boyeson water pump cover and impellar? Is it worth the purchase?
Evans is a different animal and does not mix with anything else. It does not boil.
The easiest is adding more coolant
By the way unless it is boiling over it is not overheating. If it is boiling over and you run it dry enough you will fry the top end.
I don't run poison boyeson impellers or covers. They may make a minor difference.
