Quick question
Okay, maybe the one on my 98 is after market then because it hangs down lower and hides the top of the engine.
Must be at least a 4 gallon tank, to hang low like that.
Standard XR400 tanks are all the same except white up to '99, red from 2000.
'96-on XR250 tank is narrower up the tunnel and won't fit over the spine of the 400 frame.  Not sure of pre-'96 250 tanks.
so far as i know, pre 1996 xr250 tanks are different to post 1996. The mountings are different. the early ones have a single central hook to pick up a wire frame loop, the later 250 tanks have a hook each side. the rear bolt mountings are also different.
