KMX 125 not starting
Hello,i`m new here,and have a problem with a kawsaki kmx 125 98`.
Kmx125 was runing ok,always started at first/2nd kick,no problems at all,after ride next day washed with a pressure washer,tried to start,not starting.No worry maybe somewhere water,week later still not starting.
Checked spark,ok,(https://goo.gl/photos/fVjqA7yL6wtFYP7N8)tried antoher spark plug,ignition coil,still the same.Carb is clean.Spark plug is wet.Sometimes when kicking i get sound like it is misfiiring.And thats all.I don`t know what to check.CDI not easy to check and be sure that it is ok...
I think that cdi ok,because i get normal spark...just maybe not in time?That could be a problem...
Will wait for ideas before tryning to dissasemle cdi unit and try to repair it`s not very high tech unit according to schematics...
Thanks
Edited by Irmantas Irmis
ok checked air filter clean,checked reed valve-ok,chechked pickup coil reisitance ok,not short or infinity,all conections are ok,discconected alternator.Everything the same spark is ok...sometimes missfires...
