Wr450f 2009 fork oil capacity
Hi im about to rebuild the front fork in my WR and im trying to understand how much oil i need to buy for it? Im going to rebuild the whole thing so its for both suspensions. Thanx
95-150mm from the top of outer tube with inner tube and damper rod fully compressed without spring installed. Standard level is 132mm (5.2")
I recommend downloading service manual. It's free online. Also there's a couple of you tube videos of guys rebuilding our forks. They helped when I did mine.
I did my fork seals on my 08 this spring and used almost 3L with just a little spillage. I would think the forks for an 09 would be the same as an 08?
