Brake fluid leaking near master cylinder
So, I went to ride my wr450 today, front brake was working fine at first. Got probably 20mins into my ride and the brake slowly went from good pressure, to absolutely none at all.
Got back out of the woods, started looking at the brake line, didn't see anything wrong at first. Then I looked underneath the handlebar around the master cylinder and saw it was wet.
Im not sure exactly where it's coming from, so any help would be great. I feel like it's where the line connects to the cylinder (where my finger is in 2nd pic)
any suggestions?
Looks like you've found the source of the leak?  Snug up the banjo bolt that sandwiches those two sealing washers..... if that doesn't cure it, put in two new washers.
