top end gasket kits?
I think I may need to replace the cylinder base gasket on my 04 YZ250f.  Is there any difference between OEM and aftermarket gasket kits?
yes always buy OEM gaskets. You will thank yourself in the future.
Depends on the aftermarket company. Cometic is 100% reputable. But you are talking about saving just a few dollars.
If you pull the barrel, you will have to re-ring the piston and prep the barrel too. If you remove the piston, you will need to replace the circlips also.
