08 yz450f burning oil.
Long story short I preformed a full tune up on my bike. Including a oil change. I decided to add some Lucas oil stabilizer. Before this my bike never burned oil. I do an oil change about every 5 hours of engine hours. I'm curious to as if the stabilizer is causing this or another issue. Compression is still really good and bike fires right up hot or cold. Doesn't run weird at all but it's burning oil. Coolant is clean as well
Ditch that crappy diesel oil stabilizer and start over.
gonna re do it today. Just weird wanted to see if someone else has the same issue. Never burned oil just on normal lol
How much oil does it use? Remember they only take a quart.
That's all I have put. Not much. I'm almost wondering if its residual. I can't drain it from the second plug either only the front one.
You should be draining with the drain plug on the right rear.
Well shit. I've been using left front
Just drained it and holy cow a ton came out hah
