Rmz supermoto
May I ask what you mean by the rich plug? You see I have been playing with the carb on my bike it has a boyesen quick shot on it and is jetted pretty rich to run at sea level and up to about 1500 ft. I have rode it at higher altitudes such as 4000 ft and it ran okay but just okay. I think if there was a hotter plug to run it might help. I don't want to reject because I love the way it runs where I usually ride it just seems to be a hair too rich so when I climb alt it crosses that line. I was thinking a k n air filter for the higher air flow to kind of counter the richness.
It's a map plug for the FI bikes.
Ohlins TTX √
Magura 750 radial brake √
5" Rear √
Michelin Supermoto Slicks √
Braking 320mm rotor √
Akrapovic Ti Exhaust √
VP U4.4 Race Fuel √
Toxic Moto Chain Block √
Race sponsor livery design √
Edited by zibbit u2
On 7/6/2017 at 9:27 PM, zibbit u2 said:
Ohlins TTX √
5" Rear √
VP U4.4 Race Fuel √
How are you fitting the Michelin rear? I am building my 2015 and the Michelin rear was to wide, had to go Metzler.
The rim was offset and it's still ridiculously tight, so I know there will be chain slap on the tire.  I was running a set of Metzlers Racetecs before and the chain was chewing up the corner edge of the tire.
Here's some measurements from the bike:
LH swingarm to rim: 3.1cm
LH swingarm to sprocket: 1cm
LH swingarm to tire: 1.9cm
LH chain to tire: 0.1cm :o
RH swingarm to rim: 1.7cm
RH swingarm to brake rotor: 3.1cm
RH swingarm to 0.4cm
I do have a Toxic Moto chain block installed, so the chain shouldn't do too much chewing on the michelin even with 0.1cm of clearance.. haha
Edited by zibbit u2
