CVK40 Model years
Was looking into a CVK40 swap, and am trying to determine if the the 2008 onwards klr650 carbs could work. Based on bike bandit, they indeed are different part numbers.
Has anyone here successfully completed a swap with the carb off the newer KLR?
The carb would be basically the same , they didn't change much other than some of the jetting and brackets ect.. . Would be the same swap . A carb off a KLX650 will work as well , they are the 40mm CVK's , I have 2 laying around here.
Edited by jjktmrider
  • Like 4
Sounds good.
Also, if you ever want to get rid of one of those carbs, just lmk ;)
