Piston slap
My engine was built by ken Oconner racing. I have noticed that off the pipe but about mid throttle that I have piston slap. I'm running 93 non eth fuel. 32:1. Zuk needle with a 168 main and a 42 pilot. I was wondering if it could be timing issue. I have no experience with timing a 2 stroke.
Piston slap is a rattle that is most prominent at idle speed.  You must have something else going on.
'off the pipe' and 'mid-throttle' doesn't quite sound right,
on a YZ250, I'd think by 1/4 throttle you'd be into the powerband.
If you meant re-accelerating while in a gear high (lugging) then I'd suspect detonation rather than piston slap noises.
Since you're already using 93 octane gasoline, sounds like you might have to correct the squish band height.
Yes sorry. Only while lugging. 3rd gear or higher. I have access to 100ll fuel. I thought about mixing a couple gals in to see if it helped.
Increasing the octane is just a band-aid,
either stop lugging or, if it hasn't been done yet correct the squish height. (known issue with the YZ250)
