1995 XR100 rear hub bearing tollerance
Does anyone know what the limit for the rear wheel bearing bores? the manual does not say I purchased a set from boss bearing and both sides slide right in. So I don't know if the bore is out of limit or the bearings are too small. I measure the OD of the new big bearing 1.550 and the ID of the hub big bore at 1.550. The small bearing OD is 1.258 and the ID of the hub small bore at 1.257. So i'm at a loss, any help would be appreciated.
You left out one of the key pieces of information.............how did the old bearings fit in the hub when you removed them?
Also be careful as there are lots of cleverly counterfeited bearings of poor quality being sold!;)
Old School Al
