Transmission vent line
Can someone tell me where the vent line for my transmission is? '07 300xcw....I cannot seem to find it although I may be looking right at it and not realize it lol. Thanks.
I would assume your '07 is like my '13 in that regard, there is no specific "trans. vent "line". There is a vent line at each side near the power valve linkage covers, and on mine, if you look/feel carefully, at the bottom the stator cover where it mates to the engine is a spot in the edge of the cover that allows venting.
Rt side PV galley.  on top.  Here's a tip replace the small OEM line and ditch the crappy plastic fitting on the frame that it attaches to.  Run a larger hose and curl it back exiting by the carb..  The plastic POS only has a small opening to vent and will get clogged up causing the tranny to pressure up and blow a gasket.  Been there
