DR-z400E 2000 wont start when hot
Ok, came back from the shop.. they replaced the pickup that is located close to the flywheel.. now it starts good.. lets see how it goes.. i will do a testdrive now
I apologize for the bad English.
What is a pickup truck?
I have the same bike only in kickstart.
changed the connecting rod, assembled and can not start. (..
sorry for my bad english too.. i changed the stator pickup.. a small ""magnet" wich is connected to the stator, and is located on the flywheel..
so i took the drz home, and no issues whatsoever..  tomorrow gonna ride a little bit more to make sure it is ok to go for a 3 day ride..
Good luck , hope that took care of it . It'd be a pisser to loose a paid trip.
Yeah man! thanks for replying.. hotels and food etc.. was expensive, but life isnt just work..
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
