2014 sxf 450 clutch problem !!
hi all having problems on a sxf 450 I have just replaced the clutch collar and bearing on I'm now awaiting a new piston as the seal is &%$#@!ed on it but before that It was getting clutch drag and the clutch lever kept going solid couldn't get it to bleed atoll  ? also the pushrod does the cylinder side go towards the clutch or the push rod piston as there is a flat side and a curved side on the push rod one more thing there was 2 spacer plates stuck together surely this isn't normal ? if it take one of them out it leave the plates very loose like its meant to be there surely not ?
need urgent help on this folk cheers
