Bike wont start. HELP!!
A while back i was riding my 1995 KTM 300 EXC and then the next day it refused to start. I made sure that it wasn't my carburetor, so the next thing i could check is my stator. Now im not sure what it is suppose to read but i tested each wire and this is what each read.
Black wire to Red wire - 1.531 Meg Ohms
Green wire to Red wire - 1.531 Meg Ohms
Green wire to Black wire - 173.1 Ohms
Yellow wire to yellow wire - .4 Ohms
any information anyone can supply would be greatly appreciated
Thanks!
3 hours ago, 2smokerippa said:
@Builderdude yes i replaced the plug not to long ago
Plugs can sometimes foul fairly easily, I guess I'm asking if you've verified that your getting spark at the plug. A quick plug swap would be simple and you could test it prior to installing it.
On 6/26/2017 at 0:11 PM, 2smokerippa said:
@Builderdude I have spark but it is weak. So I figured that my stator wasn't performing properly
The spark should jump at least a distance per the manual (think like 10mm/3/8 in). Get a tester at the auto store and test it right before you wast money chasing your tail. You can do this by removing the cap and holding the lead away from the case if you don't mind possibly getting shocked.
