Ltr450 won't get spark
I'd figure out where the wires go to, check to make sure power is getting everywhere, check coil
Coil wire had a short in it making the voltage go all over the place when I tested it. Ordered one earlier so hopefully it helps. Stator tested good, and couldn't find how to test the rectifier or the cdi
Sounds like that might be the fix. Otherwise I think a cdi is pretty cheap too
Cdi is $179 used so hopefully don't end up needing one. Hopefully the new coil solves it. I started going through all the wires today and the only ones that seem to be unplugged are for lights. Going to start organizing them tomorrow
