How to soften these stacks?
RMZ 450 - SFF Spring Fork
Forks feel pretty good, but very stiff and some flat landings hurt my wrists, any ideas? 180lb, fast vet. 1.0 Spring and 310cc each leg
BASE VALVE
32.2 x4
32.1 x12
24.1
31.1 x12
30.2 x2
29.2 x2
27.2 x2
25.2
23.2
21.2
19.2
17.2
23.2
Plate
REB/MID
6mm  ID
14.1 x3
13.1
Collar 2.5mm
8mm ID
24.1 x6
26.2 x6
8.3
6mm ID
26.1 x6
16.1
24.1
22.1
20.1
18.1
16.1
14.1
13.1
Edited by Rotaholic
The 17 kxf 250 has pretty plush stacks, maybe compare those ?
BASE VALVE
32.2 x4
32.1 x12
24.1
31.1 x12
30.2 x2
29.2 x2
27.2 x2
25.2
23.2
21.2
19.2
17.2
23.2
Plate
REB/MID
6mm  ID
14.1 x3
13.1
Collar 2.5mm
8mm ID
24.1 x6
26.2 x6
8.3
6mm ID
26.1 x6
16.1
24.1
22.1
20.1
18.1
16.1
14.1
13.1
I've never worked on this specific fork but I would do some combination of the following.  Depending on how much softer you want to go, you can remove a few face shims.  Or, you can add more taper, ending on a smaller clamp shim on the BV.  Softening the MV will have a direct effect on the feedback through the bars.  Adjusting the BV will have some effect on the feel and can also affect ride height.  If you're sprung correctly and it dives too much, you probably need more BV.  Some suggestions below:
BASE VALVE
32.2 x4 (remove one of these)
32.1 x12 (remove 2-4 of these)
24.1
31.1 x12
30.2 x2
29.2 x2
27.2 x2
25.2
23.2
21.2
19.2
17.2 (adding more taper, like 16.2, then 15.2, 14.2 under this one will also soften the whole stack)
23.2
Plate
REB/MID
6mm  ID
14.1 x3
13.1
Collar 2.5mm
8mm ID
24.1 x6
26.2 x6 (Remove 1 of these)
8.3
6mm ID
26.1 x6 (Remove 1 or 2 of these)
16.1
24.1
22.1
20.1
18.1
16.1
14.1
13.1
You can always put them back.  :thumbsup:
BASE VALVE
32.2 x4
32.1 x12
24.1
31.1 x12
30.2 x2
29.2 x2
27.2 x2
25.2
23.2
21.2
19.2
17.2
23.2
Plate
REB/MID
6mm  ID
14.1 x3
13.1
Collar 2.5mm
8mm ID
24.1 x6
26.2 x6
8.3
6mm ID
26.1 x6
16.1
24.1
22.1
20.1
18.1
16.1
14.1
13.1
is that supposed to be 26 - .2 on the mid comp or 26 - .15?
Edited by Dougsey
