Good shop air conditioner?
On my 4th Florida summer and I'm going to break down and buy and air conditioner for the garage. Just too damn hot & humid to get any work done. After 15 minutes of basic bike maintenance, I have sweat pouring in my eyes. So, you could say that I'm a big ol' pus'. With that out of the way, I have no widows, so looking at portables like these:
https://www.amazon.com/gp/search/ref=sr_nr_p_76_0?fst=as%3Aoff&rh=n%3A1055398%2Cn%3A3206324011%2Cn%3A3737671%2Cn%3A14554126011%2Ck%3Aportable+air+conditioner%2Cp_n_feature_four_browse-bin%3A14554145011%2Cp_76%3A1249155011&sort=smooth-review-rank&keywords=portable+air+conditioner&ie=UTF8&qid=1498487713&rnid=1249153011
Anyone using a portable? If so, what make/model and how's it work? Need something for a 650 square foot triple.
I don't know much about air conditioners but I feel your pain.  High of 67 degrees today Michigsn I might have to break out a beer cozy to keep my beer from getting warm.
Doc
Doc
67? I'd be asking about heaters then! ;)
  • Like 2
What do the portables do about the water? I don't see one working properly in a very humid area like mine.
I have a 600 sq foot shop in the desert of SoCal.  I can't recommend a mini split system enough.  Something like this is affordable, a handy person can do 90% of the install and then call in a liensed AC person to draw the proper vacuum and charge the system.
I have a unit from a company called Gree, it is a heat pump and AC in one and kicks ass.
A unit this size heats/cools my 600 sq feet like a champ.  https://www.comfortup.com/gree-vir18230-145815-18-000-btu-20-seer-wall-mount-mini-split-air-conditioner-heat-pump-208-230v-15-line-set
  • Like 2
4 hours ago, Bryan Bosch said:
Gets dumped into an internal tank that you drain periodically. My buddy moved here and lived with me a bit. I got spoiled using his.
OK, you go first and then let me know.
I've used my buddy's and it worked well. But, I need to insulate my garage doors and toss in some insulation above the drywall in the garage for full efficiency.
I think I'm going to go w/ this...
https://www.costco.com/De'Longhi-Pinguino-14%2c000-BTU-3-in-1-WIFI-Enabled-Portable-Air-Conditioner%2c-Dehumidifier-%26-Fan.product.100340308.html
At least with Costco, returns are easy for any reason if I hate it.
I ran a 240VAC dedicated circuit, cut a hole in my wall, framed it out and shoved a window unit in it about 18 years ago.  2.5 ton unit still runs fine.  If you have a roll up door that is not insulated I recommend insulting it, especially if it gets direct sun.
Get one of those big like 3 foot by 3 foot coolers. Those things work good! Just have to make sure you have your door open when you have it on, otherwise it'll be super humid in your garage!
If I open my garage door, I'm just letting in more heat & humidity. I don't see an evaporative cooler as a viable solution for a Florida summer. I ended up buying a 14k BTU rolling AC unit that exhausts the hot, moist air outside. I ran in for just 30 to 40 minutes yesterday and it took a hot, sticky garage to a reasonably comfortable working temp with a good drop in humidity. On hot days, it's not going to be a meat locker, but as long as I don't have sweat flowing down my butt crack and into my eyes, I'm good! :)
We have a portable swamp cooler that works fine in our shop.  But I live in the high desert SW where there is usually very little humidity.
We used them in our shop in Vegas for the same reason: high evaporation rates.
"sweat flowing down my butt crack and into my eyes" Are you hanging upside down in your garage? ;) But hey that's good, an A/C unit is always better. Keeps you nice and cool minus the humidity.
