Bike makes squeaking noise when being pushed
The rear of my bike makes a squeaky noise when I push it I can't hear it when I'm riding only when off and pushing it's coming from the rear any ideas where it's coming from?
Pull the wheel and check the wheel bearings out.
Chain, rear wheel bearing, shock linkage bearings, also if the kickstand is contacting the swingarm it can squeak. Check the easy stuff first.
If you suspect rear wheel bearings first get it on a center stand and turn the wheel by hand to feel for resistance/squeaking. Then remove the wheel and turn the bearings by hand to feel for unusual resistance, scraping, squeaking, grinding, etc. Bearing should turn smooth, even and quiet.
Brakes stuck caliper?worn pads?
Just put new rear pads a few months ago
The caliper could still be stuck and causing a pad to drag lightly.
Ok so lubed everything new chain and sprockets and now the noise is gone! YAY
Thank you guys so much the pointers were helpful c:
  • Like 3
