Fork conversion fitment
I'm wanting to put 2009-2010 forks on my 2017 Kx250f. Will the 17 wheel and caliper fit the 09 forks, will the forks fit the 17 triple clamps?
Does anyone know what the measurements for the upper fork tubes where they slide into the triple clamps are?
Why would you want to do that?????? The 17 SFF are a vast improvement from 2011
i believe the brake rotor is biigger. but im pretty sure they would bolt right on
the rotor is bigger but the caliper will bolt direct to the forks. The only change is upper clamps on the triple clamps are slightly bigger on the 17. I found a friend that had put these forks on his 2017 as well.
You should be able to find older model triple clamp parts all over ebay
