How should I fix this?
The chain went off the rear sprocket and bunched up in the front which busted the engine casing where the clutch sits (as shown in pic). My clutch has either gone lose/tight OR busted as its already engaging in 1st gear while holding on the clutch on neutral. Question is, how do I go about adjusting my clutch, and also how am I going to fix the damage piece on motor? Is there some sort of putty that will work?
Your suggestions are highly appreciated!!!
New/used case half, bearings, seals, and a CASE SAVER! People that pull them off and run without are just asking for your pain.
  • Like 2
Jb weld if you want a quick fix but eventually you will need a new case half
