05 Rm250 rattle/vibration
Im getting ready to work on my nephew's bike just wanted to get some ideals first.
It has a rattle in the clutch side somewhere and a bad vibration! Any ideals before I open it up appreciated
RM's are notorious for soft clutch baskets. It's probably notched to heck and back.
Big vibrations could be anything from loose motor mounts to bad main/ crank/ clutch bearings.
When was the last time all the motor bearings we're replaced? If it's been more than a couple years or you don't know the answer, then it's probably time.
Ok , so I've got into it. Basket was wore but not terrible and I've filed grooves flat, changed bearing even thou it didn't seem bad! Rode it Abit and no noise! Changed oil n rode again (20 min) and still nothing and I hammered it! Compared to my 01 yz 250 it does vibrate like crazy but no noise! Any ideals?
I've seen the rubber cushions get wore out on clutch hub and rattle viberate.  Also even kick starter idler gear get wore and rattle.  Could be few different things.
