2006 KX250 Cylinder Breathing hose
Hello guys,
On my 2006 KX250, I replaced the entire cylinder and did not order the breathing hose fitting that goes into the left side of the cylinder.
Anyone have ideas or methods on removing it? It is currently sitting in penetrating fluid, would NOT turn or come out with vice grips and dont want to ruin it (will take 2 weeks for me to get a new one).
Best thing you could do id say is trying heating up around it and pray lol that it doesn't break
Edited by Motox367
Going by what it looks like close up - - id say its probably just pressed in with maybe some loctite - insert something in the end the same diameter - then using heat and vice grips twist it out
Looks like a press fit to me, apply some heat around where it is mounted and see if you can pull it out.
