valveadjustment Gio X31 250cc Valve Adjustment (low compression)
Hey all! I have a 2011 Gio X31 250cc that is losing compression gradually. It had amazing compression when it was new...but now it's becoming a tiresome task to kick-start when my electric start is down. It's burning a small amount of oil, but I don't even have to top it up between oil changes (~10 hrs. per change). I'm thinking it just needs a valve adjustment to bring the compression back up. I'm surprised how good this engine has been. I ride it hard and it keeps up with bikes 2-3x the hp and refuses to die! I don't know how to adjust the valves on a 4-stroke, let alone a Chinese one. If any of you know how to adjust the valves on a Gio X31 250cc I would appreciate the help! Do I need to pull the engine for this?
Thanks
You'll probably have much better luck getting a reply to your question if you post it over on THIS SITE. There's a lot of good technical information on the 250cc bikes.
