air leak on carb boot
I have an air leak between the "carb insulator" thats what the poem part is called i guss, and read cage. there doesn't appear to be a replaceable gasket here. Do I just need a new one? can i use yamaha/honda bond?
Theres a gasket between the reed cage and the crankcase but not between the reed cage and the insulator.
You could some yamabond between there
Hows the gasket between the reed cage and the crankcase ?
If it still leaks after the yamabond then your insulator or the gasket could be leaking.
thanks I replaced the gasket and when you look at what they call the insulator it looks like it should have a gasket but it doesn't.
